kennethwooster's avatar
Feb 27, 2016
Dually tire question.
I have a 2014 F350 DRW. I probably have about 16,000 miles on original BFG. I was thinking about rotation the tires, and while looking real close I noticed both out side duels were way down compared to the inside dual. I know I must rotate, but want to slow up this excess ware. I figure I probably need to lower the tire pressure on the out side dull. Just wondered what some of you are doing to keep the wear even. I run tire pressure at Ford's recommendations which is 65 on the rear.
  • Check your air pressure of the inside duals compared to outside. If outside wearing more, might have more air than inners. When not towing, I run rears at 45PSI and fronts 55.
  • We rotated at 3k, 8k and 16k, along with synthetic oil and filter change. Tires are wearing evenly and engine running smoothly.
