TxGearhead wrote:
path1 wrote:
donn0128 wrote:
I took the extensions off and threw them away. Instead I use a basic plastic cap. I find it easiest to use a dual head tire gage and a dual head air chuck. I can reach between the tires easy enough.
Correct, just get the correct tools to get to them. And save all the other hassles.
I have the correct tools; dual head chuck and gauge.
The chuck does not engage the valve straight on. I have limited access because the holes in the wheel aren't big enough diameter to angle the chuck.
I had to get a cheap tube bender for 1 tire that point off center.
