LarryJM
Jan 08, 2014Explorer II
westend wrote:
I wonder how a leaf blower and a furnace filter to catch the debris would work?
I know you and a couple of others are actually trying to help and offer solutions, but I think if you found what I did and saw how flimsy and fragile this ducting might be I would again caution one NOT to attempt anything that might put undo stress on this ducting. I for one sure would not be trying to pressurize or attempt to use something like a leaf blower in fear of "blowing" any duct connections apart (I had a couple because of the long runs of close to 20' for one duct) or even blowing a hole in the ducting itself. I think the ducting might be paper thin because that provides better heat into the enclosed underbelly by simple radiation so it's now one of these "TWO SIDED SWORD" things where a singular purpose trumps all other considerations. In general if you have an enclosed underbelly with the ducting in there it's not generally easy to get access to major areas of the underbelly to inspect or fix things and you might only know you have created a big issue is when you are freezing on that first cold day 6 mo from now because something is now wrong with your hidden and fairly inaccessible heat system ducting.
Just due to the "NATURE OF THE BEAST" some of these RV systems are very atypical of what we think of based on our normal experiences and we need to be every mindful of that when we start "MUCKING" around with them.
Larry
44,070 PostsLatest Activity: Sep 18, 2026
