- Old-BiscuitExplorer IIIDbl post
- Old-BiscuitExplorer IIIJust be careful......
A lot of rv furnace duct work in trailers is just flexible spiral wound plastic or reinforced aluminum foil type material.
Similar to a dryer vent duct.
Held in place with spring clips.
Easily torn or dislodged.
EDIT: to correct image - 74alexExplorerFeed a plumber's snake to the next register, tie a good size rag on the end and pull it back. Repeat as required.
Alex - ScottGNomadShove the flexible hose of a vacuum down there.
- newman_fulltimeExplorer IITake the vents off run a piece of mechanics wire roll a towel up and pull it from one vent to another till it is clean
44,056 PostsLatest Activity: May 04, 2014
