Trackrig
Aug 29, 2014Explorer II
It's easy to carry them in the back if you have tie down points in each rear corner of the truck bed. If so, put the tank, or tanks, against the tail gate, in the middle of it. Then run a good ratchet strap from one corner to the other, over the main part of the tank where the handle meets the tank. Don't run the strap threw the handle or over the handle, but on the tank right where the handle is welded on. This will hold them down and tightly against the tail gate.
The other way is to put them in a milk crate and up against the front of the bed. Again they should be secured with a ratchet strap to keep them from moving.
Bill
Bill
44,059 PostsLatest Activity: Mar 18, 2026
