pratmaster's avatar
pratmaster
Dumb question about truck camper tie downs
OK, so looking at all types of truck camper pictures, both on and off trucks I have noticed that most all truck campers are "tied" down to truck with the same type frame mounted system from various manufacturers, but basically the same concept.
I am referring to the type like the Torklift systems.
Every picture I see of a camper on a truck with this system, the mounting parts, happyjack, turn buckles etc. are all vertical. Straight up/down from the mounting point on the truck and camper.
So what keeps the camper from sliding out the back of the truck on steep inclines or any other situation where the truck would be pitched to where something would slide out the back.
With the "ties" vertical, there would be, what about 2 foot of room for them to slide backwards (away from the cab). The front of the bed keeps it from moving forward(toward the cab) but what keeps it from moving out the back?
Again, just looking at pictures it looks to me if you pulled off a little hard on a incline, the thing would slide back a few feet. So tell me why it wont.
  • The fact is, the tie downs do not do as much as most people think they do. They are not intended to hold the TC on the way truckers use big straps to hold loads on. They are intended to prevent the minute vibrations from walking the TC back and forth on the truck. Especially to keep it from walking out the back of the truck.
    Ideally, you would have the two tiedowns at front at an angle opposite the rear. If the tie downs are straight up and down, they will minimize the distance the TC can travel, but not as efficiently as if they were mounted at an angle.
    The TC will move around a little, but not come off the truck under normal use of the truck/TC.
    Wayne
    Most, if not all, truck camper manufacturers recommend that a rubber bed mat be installed between the truck bed and the camper bottom. This mat keeps the camper from sliding front to back and side to side. Pickups do not have enough power/traction to climb a hill so steep that the rubber mat would allow the camper to slide rearward. The front bulk head of the truck bed keeps the camper from sliding forward during a very harsh sudden stop.
    LeRoy
  • I personally would much rather cross the mounting ties, the front point on the camper to the rear point on the truck, the rear on the point of the camper to the front point of hte truck.
