c3saving wrote:
. . . But the other dump site was quite a bit different. The concrete pad and sewer hole were contoured and quite deep. Definitely not something you would want to accidentally drive into. I noticed trailers pulling past and then backing up over this fairly deep hole and dumping with no hose. Is this the correct way to use this type of dump station? Are there two different types of dump stations - hose and no hose? What is normally found at state parks? Thanks for your wisdom.
This type of common dump station is pretty common. I can't speak for all states but most of the state parks I visit do it this way, not a drain at every site. The sides slope to catch spills. That said everyone is still supposed to use a hose. A lot cleaner and less messy and stinky. Those that dump without a hose aren't very considerate or smart.
