Engineer9860
Jul 07, 2013Explorer
justALnow wrote:
Well Guys, I've been following the thread and trying to decide what to do. I appreciate the valid information.
Still digesting it all . . .
I would consider the advice of the guys that say you are hydrolocked. I've seen it on a 7.3 Ford.
If you can drain the coolant from the affected cylinder your truck will probably start. I'm sure if your problem is the head gasket(s), everything else that you mentioned in the OP is collateral, and will be fixed by the replacement of the head gaskets.
Lots of luck. :)
