ib516's avatar
ib516
Explorer II
Jul 04, 2017
Duramax Torque Management
So I know there's a lot of talk about Tq management on these forums.
For those who aren't familiar with the term, "torque management"
is a term used to describe the situation when a manufacturer purposefully reduces engine output/power by computer in certain situations to protect various parts of the driveline such as transmission and axles.
In this video, the Chief Engineer for the Duramax HD trucks says they limit power in 1st gear, and full power is available in 2-6th gears. It would be nice to know (from a reliable source like in this case) in which gears Ram and Ford limit output. I'm confident they both have the same feature.
Here's the video interview:
VIDEO
Note that I modified the link so the video starts at the point where tq management is discussed (12:48).
  • transamz9 wrote:
    The Aisin locks the TC in 2-6.
    I am not saying you are wrong, but I could have swore that one of the tuners on the Cummins Forum said it doesn't lock up in gears 2 and 3 while accelerating. From what I remember, he said it is only on deceleration while the exhaust brake is being used that it locked up in those gears just like the 68RFE.
  • ShinerBock wrote:
    I know that the Ram Cummins 68RFE does not give full power or lock up the torque converter until 4th gear when accelerating. A locked torque converter will send 100% of the engines horsepower to the transmission, and an unlocked torque converter will not. This is one major reasons why a Cummins feels so sluggish off the line versus a Duramax.
    My custom tune locks the TC from 2-6th and makes a world of a difference in the trucks off the line acceleration without adding much power to the engine. Once the torque converter locks, the truck just pulls like a train. Without it locked, it just makes a lot of noise at higher rpms going nowhere fast.
  • Thanks for sharing, i had the Tq management reduced on my truck via tune, what a difference.
  • I know that the Ram Cummins 68RFE does not give full power or lock up the torque converter until 4th gear when accelerating. A locked torque converter will send 100% of the engines horsepower to the transmission, and an unlocked torque converter will not. This is one major reasons why a Cummins feels so sluggish off the line versus a Duramax.
  • Very interesting !!!!
    Proof too that ignorance is bliss...until something goes wrong...then the questions of 'why????'...to then argue against info/advice/etc based on their ignorance...PS...ignorance does NOT mean dumb...but uneducated on that topic...
    How about some info on when they start cutting 'power mode' and how many they have (secret and think not going to get much info there).
    Again, very interesting and thanks for the post...appreciate it
  • ib516 wrote:
    DownTheAvenue wrote:
    Why? What you do with the information? What difference does it make?
    1. Because.
    2. I'd chisel it into the side of a mountain.
    3. It helps me pick my lotto numbers.
    LOVE IT!!!!!:B
    1. Because.
  • Not much can be done with it, but still good to know from a consumer stand point. I see TM as a good thing to limit driveline wear. Of course there are cases when someone may want a modified tune to have that removed.
