MNRon
Aug 04, 2019Explorer
Duramax Turbo
I have a 2013 Duramax with 130k miles. We’re in the middle of a 6k mile trip pulling 15.5klb 5er and I’ve started to get a turbocharger engine code (P2599). This first happened 3000 miles ago when...
ACZL wrote:ib516 wrote:ACZL wrote:
If your oil is low enough (approx 2 qts), add 2 qts of Hot Shot Secret Stiction Eliminator. 60 bucks or so and $$ back guarantee. Worth a shot and a lot cheaper than a new turbo.
I'm not sure I see how an oil additive can fix sticky turbo vanes.
As you know, oil flows thru the turbo and the vanes pivot inside the turbo in some fashion. Anyways, the oil can get burnt onto the inside of the turbo and pivot points and that's what's called "Stiction". The HSS has ingredients in it that will clean off the burnt oil and return things pretty much back to orig cond if not all the way. Another result of that it's working is after you put it in, start engine and run it, you'll see white smoke out of the tail pipe. Doesn't last forever.
Lot cheaper than a new/re-man turbo and labor. If it doesn't work, can always get your $$ back.
