MNRon
Aug 04, 2019Explorer
Duramax Turbo
I have a 2013 Duramax with 130k miles. We’re in the middle of a 6k mile trip pulling 15.5klb 5er and I’ve started to get a turbocharger engine code (P2599). This first happened 3000 miles ago when...
S Davis wrote:
I would recommend a Edge insight, they are more money but they give you a set of gauges that can monitor just about every thing. I have one screen set for desired fuel pressure and actual fuel pressure. The other screen is turbo boost and turbo vain position. It will also monitor the soot level in the DPF filter and even let you initiate a regen cycle manually.
