Cummins12V98
Feb 17, 2020Explorer III
Dead flat no wind conditions towing 29k combined thru Salem, Oregon on I-5 I would get the exact same mileage in 6th at 62mph as 5th. Once getting farther South around Eugene where the road started getting into the small hills It would pop in and out of 5th. I compared that mileage to locking 5th and 5th was a bit better. I finally just locked out 6th towing at 62 and would have my rpm's at around 1,750 and it performed flawlessly dropping gears as needed. With the 68 I could drop a gear once rpm's started dropping trying to hold my speed on a steep grade. Sometimes it worked and sometimes it made no difference.
With my 4.10's AISIN I tow in 6th same RPM as I did with the 68. I have tried dropping a gear once it starts loosing speed and it just stays where it needs to be and shifts as needed. It simply knows where to be.
They both worked great towing heavy but the 3.42's needed the lower starting gears on a grade the AISIN gives.
ONLY change to the AISIN I would like to see is the ability to lock out first and start in second while unloaded.
