wowens79's avatar
wowens79
Explorer III
Oct 03, 2017
Duramax, warm up time
I'm considering a 2015 Duramax that a friend is selling that is pristine and well maintained. He drives a lot, it already has 115,000 miles on it.
I on the other hand have a short commute only 6 miles each way. I keep reading that short runs are rough on the new diesels because they don't get up to temp. Would my short commute be to short to warm it up good?
I live south of Atlanta, so in the winter, it's not like it will be really cold in the mornings. Not sure if that really matters.
  • My 2013 Duramax was used as a daily driver from our home in North Augusta, SC, to downtown Augusta, GA, (8 miles and a little over 15 minutes) for three years before I retired and hit the road. I idled it for a few minutes in the winter before pulling out of the driveway on cold mornings. Once a month or so, we took it out on the highway and it was used for road trips and to pull our travel trailer. We never had a problem with it. Once we hit the road full-time, it pulled the fifth wheel our first 11,400 miles. Great truck!
    Rob
  • If you do go that route regular use of a block heater would help by shortening your warm up time.
  • Problem is, it needs to go into regen once in a while. You might be able to force regen manually, not sure about a GM. Not really 'warming it up' more about exercising the pollution controls.
  • In a word, yes. The current emmission systems need to come up to full operating temp to function properly. You would be better off to get something gas powered for your short commute.
  • If the 6 mile commute back in forth it the predominate use of the vehicle, especially if it involves a lot of stop and go driving, it is going to be problematic with any 2008 and later diesel because they use a DPF (diesel particulate filter). The DPF traps soot and must periodically clean itself by burning off soot and this requires around 30 miles of driving at 30 MPH or above to complete the cleaning cycle. It doesn't have to complete it in one drive but cleaning doesn't start until the filter is hot enough and if it is unable to complete in a reasonable amount of time you will get a message to continue driving at speed until it completes.
    The Duramax engine has one of the better systems for this because it uses a separate injector to dump raw diesel in the exhaust stream rather than injecting it into the cylinders on the exhaust stroke like Ford which creates potential for cylinder wash down and oil dilution. But none of the systems work well when driving consists primarily of a number of short trips. You will also find mileage abysmal with any of the large diesel pickups in short trip stop and go driving due to both slow warm-up and the physics of frequently launching a near 8,000 pound vehicle. I am on my second Duramax equipped GMC and am about to order a 2018 but for shorter necessity trips I drive a Cadillac ATS and for short fun trips if it isn't too cold I drive a 2016 Z06 but its summer performance tires are not any fun below 40 degrees when they are like driving on ice. For your described driving if you need a pickup but can do without a HD model a 1/2 ton gas powered pickup will probably better suit your needs.
