The_LeRoys's avatar
The_LeRoys
Duramax with Hydra-Matic a good combo?
i am used to the duramax and Allison combo in my 2005 Silverado and love it. I need more passenger room. I'm looking at a 2008 express with the duramax hydramatic combo. I know it's not as good as the Allison. But is it still good and reliable? What do I lose?
  • fireman41 wrote:
    GoPackGo wrote:
    roman traveler wrote:
    The tranny behind the 8.1 is an Allison. I owned one.
    RT
    Did you have a van/Suburban or a pickup ?
    I'm under the impression that the Allison could only fit under the pickups. That there is not enough clearance for an Allison to fit under the others.
    Don't forget that the 2500 avalanche also used the 4l80e behind the 8.1
    So did the Suburban 8.1's. No Allison because it wouldn't fit in the trans tunnel.
    RT
  • I have a small class a motorhome with 8.1 and hydramatic thats why i referenced it.
    RT
  • The LeRoys wrote:
    What do I lose?
    60 hp and one gear.
    Van and truck ratings are not the same.
  • Its the same transmission that is behind the 8.1 gas engine and does a fine job. Just service regurly and watch the heat and all is good.
  • The Duramax in the van is pretty de-rated compared to the pickup version. Issues with heat management. Don't know how long those transmissions last to be honest.
  • Wow, I am amazed they do this. I thought the only auto trans that could handle the Duramax was an Allison. They must de-rate the Duramax ??
