MO_Trout_Bum's avatar
MO_Trout_Bum
Durmax LLY Losing prime
Just wanted to get some thoughts on a sporadic problem. After an uneventful 3 hour drive back from camping, we dropped off the camper at the storage lot (truck was idling about 10 minutes); put the truck in gear and it immediately died. Would turn over but not start. All that occurred to me was, it lost prime. So I loosened the bleeder and pumped a few times (no air came out). Left it sit another minute or two and primed again, and diesel came shooting out of the bleeder. Tightened it up, and the truck started right up. Drove home and put the truck in the garage until I had time to work on it. Replaced the fuel filter as a precaution (I had just replaced < 2000 miles ago in the Fall), primed it and it started right up. Noticed some sediment in the drain pan, but not sure that is unusual. Anyway, finished the job, primed as normal and truck started right up. Truck sat in garage another week, and I took it today to the storage lot to do some camper maintenance for a couple of hours. Started truck up, put it in gear and it died. Very same scenario with the bleeder as previously... truck start up and I took it to get some fresh diesel (about 15 gallons); drove it down the interstate 5 miles or so and back, ran some errands, and no problems since. Just wondering if we got some bad diesel on the trip, or sediment in the tank from truck sitting in garage for most of the winter, or ????
Any thoughts or similar experiences?
