fordrocks wrote:
I know there is a drop in gas mileage with e85 everyday driving, But if pulling a camper and only getting 10mpg with regular gas. Wouldn't u use e85? Where I live it is .40 cents cheaper. So would u get less then 10mpg if so how bad would it get? It couldn't go under 8 mpg? Im getting my new tt 3-29-13 so haven't had any experience with this. I know my truck gets 15 more hp and 10 more torque which is to consider. I did have a starting problem it started, but took longer. Called dealership to see if they heard of it? Right away said e85 doesn't like cold so I topped off with regular never happened again. So any e85 users while towing? Thanks
You will loose right at 30%. So if you get 10 on gasoline you will get 6.5 to 7 on E85. It won't work out if you want to save $$$.
