fordrocks wrote:
Really that's crazy. I'm still going to try it, but not what I expected. I have good luck mixing 50/50. Are you guessing or have you towed with it and got these result? You always lose 30 percent? Different trailer weight has nothing to do with it? I would get about 510 miles a tank with regular and 460 with e85 regular driving. That's not 30 percent is it? Thanks
No haven't towed with it but it's easy math to do. You have right at 30% less BTU's with straight E85 so you will loose that and even a bit more because of the tune. The more gas you use the better mileage you will get.
I race against people that use alky. Straight meth not eth. On a hot day they will wax us with the same engine on alky. It makes a big difference on a hot day. On a cold day we can run right with them so not much difference in power.
Here is some math for you. It will show you why you won't come out by towing with E85.
Or you can just keep on using E85 and make the corn farmers rich and happy in the US. Your choice. :B
