av8rds
Nov 12, 2015Explorer
adambeck7 wrote:
After two or three visits they said the insulation around the fridge was incorrectly installed and that should fix the problem. Lo and behold it didn't. Back at the shop. It's overheated several times (inside fridge was 20 degrees warmer than ambient temp outside)
Thats also some of the diagnosis I got and it didnt help. As didnt making the fan have a full-time switch option to run when it was hotter out. As well as an added baffle at the top to help the hot air get out better. None seem to work.
I feel mine is also related to how level it is too. Yeah I know fridges have to be level to work right. I'm talking degrees. Or less than 2" of blocking under the front tire(low side only) to make it go from 50 inside to high 30's. I used to park my last two campers in a less level spot(6"blocking for level) and didnt have any problems. Just coincidentally moved where I park to a more level spot and have an issue.
No big deal you say. Just keep it level when you're parked....that's all well and good till I want to drive down the street. I find on a 2 hour drive, on well, un-level streets the fridge drifts up to 50 again.
I got the email from the dealer yesterday. I have call him and see if we have any progress.
I'll add my slide frame has started backing out from the camper twice now in maybe, MAYBE 80 extensions and that is being very GENEROUS.
I have ripples under the rubber roof, lots of them, all down the sides.
I have ripples under the ceiling headliner, lots of them.
I have a curved bathroom wall. I thought the door was out of adjustment when I bought it so I didnt worry too much. No the wall has a NICE curve to it.
I have a mystery hole that appeared in the fiberglass under one of the slides. It looks like a screw? or something was pushed out from inside.
My water pump is bleeding down.
my stereo had one speaker that didnt work, and the others were wired wrong. one inside and one outside on both channels so it was always playing inside and out.
I have a mystery scratch on the side of one of my slideouts where something is rubbing as it goes in and out.
I'm sure there was more but thats the bigger items.
And for better or worse I am responsible for purchasing a camper with some of these faults. I was so blinded by the floor plan, the tanks, the reputation, lack of problems in previous campers that I didnt vet it as well as I should have. I would never have purchased this unit had I done a better job checking quality. But some of these issues would never have been seen.
