69_Avion
Dec 21, 2013Explorer
dennisgt60 wrote:
Well, since you have never towed.....you won't notice the difference.
That is the correct answer. LOL
The length of the trailer isn't as noticeable as the width, when towing. You notice the width in your mirrors, and as stated previously, the aerodynamic drag is more with the wider trailers. Both my trailers are Avions, so I get the advantage of the aerodynamic shape. My shorter trailer is much higher and the reduced wind resistance makes a huge difference when towing.
You really need to decide how much room you need and then pick the trailer that best suits your needs. If you are the type of person who will spend most of your time in the trailer, bigger is probably better. If you like to be outdoors, then the size isn't as important but the towing qualities may be a top priority.
