TheGriswoldsExplorerAug 26, 2013Easy way to drain water heater?I like to drain the water heater almost every time after we use the trailer (2013 Keystone cougar 31sqb). However the Adnode (sp?) rod is a pain to take in and out just due to the angle and the amount...Show More
YardvarkersExplorerAug 26, 2013http://www.campingworld.com/shopping/item/anode-rod-with-drain-for-atwood-water-heaters-4-1-2-/37395
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsWater Heater Leak on start up.water heater drain modSuburban SW12DEL Water Heater On/OFF switch melts???
