valhalla360
Nov 16, 2022Navigator
NamMedevac 70 wrote:
Thanks. Your lynx levelers are very cost efficient. My electric tongue jack failed me at night in freezing rain, so I now use only hand crank jack. The exercise is good for me and warms me up in no time. P.S. The hand crank for my electric tongue jack was misplaced a long time ago. Cheers to the brave.
Electric, manual...still the simplest solution. Manually cranking it up 2-3 inches should take less than 30 sec.
Also, if you use blocks under the rear truck axle, you are likely to get more bounce in the trailer as the truck springs are supporting the front of the trailer.
If you put the trailer jack down, the truck suspension is isolated from the trailer.
