Grodyman
Jan 06, 2019Explorer
Ecoboost 3.5 Towing MPG Sucks
Hi all, back after a couple years without a RV......I jumped back in with a Passport Ultra Lite 153ML, GVWR of 4500lbs.
I just returned from picking up the trailer and pulled it with my 2017 F150 3.5 Ecoboost with 3.55 gears.
I was astonished to pull such a lightweight, aerodynamic trailer and the best MPG I got was 10.2 MPG. I went as low as 8.5 MPG.
I could have done better than that with my F250 with the 6.2 V8.
I am surprised how dreadful the towing MPG is with truck considering the overall weight of the truck/trailer combo is a couple thousand pounds lighter than I usually travel.
Unloaded this truck is great, but if you are on the fence about a F150 and a F250, go with the F250 gasser all the way UNLESS you drive a lot of unloaded miles.
The truck had plenty of power, no issue there, but I simply cannot imagine pulling 7K-10K lbs with this truck, the MPG's must be around 5.
My current range is about 250 miles pulling this Ultralight, given the fuel tank size. So, essentially, adding an ultralight trailer dropped my MPG nearly in half. Not what I expected.
Gman
Gman
