- Water-BugExplorer II
jerem0621 wrote:
Engineer9860 wrote:
Now let me get this right..........
A direct injection turbo Diesel engine is workable in a heavy duty pick-up truck, but a direct injection turbo gas engine is not?
Yes! Everyone knows that 6 cyl can't work in a HD Truck..... Everyone knows that just asking for mains to freeze and cranks to break. :D
Hope that was meant as a joke. RAM Cummins is a 6 cylinder. - otrfunExplorer II
CarterKraft wrote:
Makes perfect sense! But . . . human nature being what it is most likely it'll be ruthlessly compared to the 6.7 850 ft. lb. diesels and called wimpy . . .
My opinion... We don't need small displacement turbo gas engines in HD applications we need small displacement turbo diesel engines in HD applications.
Look at Cummins new 5.0 V6. 5.0 Cummins
One of the first complaints about the new Ram 1500 EcoDiesel was that it *only* could tow 9,200 lbs. Doesn't matter it's only a 1/2 ton and gets 25-28 MPG when it's not towing. - CarterKraftExplorerMy opinion... We don't need small displacement turbo gas engines in HD applications we need small displacement turbo diesel engines in HD applications.
And for clarity I am not a Cummins fan, but they have the right idea. - spoon059Explorer II
Its like deja vu all over again. Remember when the sky was falling because they were putting the 3.5 in the F150? It was such a piece of crap, no way it would last, "turbo's have no place in a tow machine", etc etc?
I don't know if it will work or not, but if Ford is smart they will at least put it through R&D and see if it is feasible. - jerem0621Explorer II
Yes! Everyone knows that 6 cyl can't work in a HD Truck..... Everyone knows that just asking for mains to freeze and cranks to break. :D - Engineer9860ExplorerNow let me get this right..........
A direct injection turbo Diesel engine is workable in a heavy duty pick-up truck, but a direct injection turbo gas engine is not? - otrfunExplorer IIOops, double post.
- otrfunExplorer II
goducks10 wrote:
The 3.5 Ecoboost has 15 lbs. more torque than the 6.2, not to mention the 6.2 develops max torque at a relatively high 4500 RPM vs. the 3.5 Ecoboosts's much lower, diesel-like, 2500 rpm. I would think the limiting factor (ref tow capacity) for the 3.5 Ecoboost F150 is the 1/2 ton drivetrain and suspension.
My guess is that the 3.5 is maxed out with the 11,300lb tow rating in an F150. Add the extra weight of the F250/350 and the 3.5 would have a hard time reaching the 15,000+lb tow rating offered with the 6.2. It works fine in it's own element.
Concerns about the 3.5 Ecoboost duty-cycle and fuel economy aside, I believe the 3.5 Ecoboost's torque characteristics would provide much better realworld performance (to include towing) than a 6.2 in a F250/350 chassis. Torque does all the work. The 3.5 Ecoboost has more and at a much lower RPM than the 6.2. - goducks10ExplorerMy guess is that the 3.5 is maxed out with the 11,300lb tow rating in an F150. Add the extra weight of the F250/350 and the 3.5 would have a hard time reaching the 15,000+lb tow rating offered with the 6.2. It works fine in it's own element.
- pronstarExplorerI can't remember any high-boost (turbo or supercharged) gasoline engines in heavy-duty on-road applications, and for good reason - duty cycle as noted above.
You do see them in boats (a high-boost, high-load application for comparison), but how reliable have they been? I know they're high-performance, but still...
I don't want to rebuild my truck engine every 500, 1000 or even 2000 hours.
As Ecoboost owners who tow heavy will tell you (IMHO the honest ones), you get poor mileage under load - you have to run really rich to prevent detonation and keep EGT's low so you don't melt cats. And by the time you build it strong enough to handle a hard duty cycle, IMHO its a pricey motor.
Plus it's hard to overcome a diesel's inherent efficiency (unthrottled so fewer pumping losses), not to mention higher BTU's compared to gasoline.
But who knows...someone will probably come up with something to prove me completely wrong LOL
44,052 PostsLatest Activity: Nov 04, 2025
