- LantleyNomad
lbrjet wrote:
Several people on the forum have experienced this. It is old news and happens rarely.
Nevertheless it is a known issue it needs to be fixed to the point that it doesn't happen at all.
Though rare these engines are totally shutting down when put under acceleration. It is a potentially dangerous situation. It is a known problem at this point.
A what point does the issue have to escalate to before a recall is done? Does someone have to get hurt first?
I don't like class action suits but I also don't like large corporations stone walling consumers and sweeping problems under the rug.
I'm sure there is a fix but is Ford going to go to the expense of issuing a recall? Bean counters rule.
Enter the class action lawyers looking for easy pickings! - 720DeereExplorerLOL! That right there is funny, I don't care who you are. The "displacement" of the hemi is too weak to even turn a top fuel blower at fuel speed! In this era of technology, there is an efficient "replacement for displacement". People that can't grasp that are usually the same ones who feel that a manual transmission is somehow superior to an automatic. Guess what guys, Elvis Presley is no longer topping the charts either.
- Kevin_O_Explorer
markandkim wrote:
That little engine as you put it is built with all forged internals and can handle much more power than they come with from the factory. That #1 rule, there is no replacement for displacement is total B.S. I know your just lashing out because your having a hard time wrapping your head around the fact that Fords little Eco V6 outperforms you big bad HEMI ! It will be ok, you are unfortunatley suffering from what us ecoboost owners call torque deficiency. ;)
You got to know, when you ask a little engine to do what they are asking there are going to be major problems. just follow the # 1 rule; There is no substitute for cubic inches. Remember when you daddy and your brother told you that? It still stands today, even with todays modern technology. - DSteiner51Explorer
Pure BS. Diesels now use turbo's instead of large displacements too. - Carrera_manExplorer
720Deere wrote:
countryboy69 wrote:
my brother has an eco boost and a vw tdi. they both got inter coolers on the same day. basically anything with and inter cooler can have this issue.
This leads me to believe that driving habits have a lot to do with the problem. Just about every vehicle I have ever owned had its own little quirk and a simple change in driver behavior usually makes all the difference in the world. People get very upset when you tell them that they may be causing the problem because even the worst driver in the world somehow feels that they have superior driving skills. A friend had his girlfriend wreck his truck a few days ago and her defense was that she "drives better than any other girl out there". I think Ms. Patrick and the Force girls would probably beg to differ!
Well she may not drive better then the Force women but she's right there with Ms. Patrick LOL! - 720DeereExplorer
This leads me to believe that driving habits have a lot to do with the problem. Just about every vehicle I have ever owned had its own little quirk and a simple change in driver behavior usually makes all the difference in the world. People get very upset when you tell them that they may be causing the problem because even the worst driver in the world somehow feels that they have superior driving skills. A friend had his girlfriend wreck his truck a few days ago and her defense was that she "drives better than any other girl out there". I think Ms. Patrick and the Force girls would probably beg to differ! - lbrjetExplorerSeveral people on the forum have experienced this. It is old news and happens rarely.
- countryboy69Explorervolks wagon has the same issue with the new tdi, inter cooler fills with enough water that when it freezes it wont start because the inlet is full of ice.
my brother has an eco boost and a vw tdi. they both got inter coolers on the same day. basically anything with and inter cooler can have this issue. - thomasmnileExplorer
boogie_4wheel wrote:
Not sure on the venturi effect... I do know a thing about carbs icing up. I had the same issue on my '70 pickup in the winter when I was in college in northern Utah. Really cold and going over the mountain pass the carb would ice up and the throttle would stick. My remedy was to modulate the throttle a little bit every couple minutes to keep it broken free.
I read more on the EB awhile back about high-humidity being a cause or magnifier to this condensation/misfire issue. I still feel that loading these things once in awhile will reduce/eliminate the problem; it shouldn't happen and owners shouldn't need to go out and flog their vehicles from time to time. It is just like when all the diesels went to DPFs. City driving, extended idle times, short-cycling, all lead to plugged DPFs. The solution was to drive them to get the exhaust gas temps up and help burn the soot out. I still feel that if these were 'worked' every once in awhile, water would not collect in the IC.
From my understanding of the venturi effect when I took flying lessons, it occurs when high moisture content air is passed at a high flow rate through a narrow passage; sensible water is essentially wrung out of the air. In a normally aspirated gasoline engine of an aircraft, ice will form even at low altitude, depending on ambient temperature (I always wondered how that could happen in Florida, but it can). In the case of the EB, the result is condensation in the CAC which apparently gets swept through the induction system and mixes (badly) with the fuel. - mich800Explorer
Carrera man wrote:
carringb wrote:
Carrera man wrote:
Two people suing and a 100 complaints out of how many thousands of Ecoboost motors? Ridiculous.
3. Jeesh. way to down play the statistics. That's 50% higher than what you reported!!!
Your right it is three. I may have to sell all of my Ford stock tomorrow LOL!
Actually the statistics are amusing. Per the article, three drivers are suing Ford. Next paragraph, two of them are married. Maybe if they had driving age kids they could have brought it to class action status.
44,052 PostsLatest Activity: Nov 23, 2025
