riven1950's avatar
riven1950
Ecoboost transmission temp
I just purchased a new 2013 F150 Ecoboost. I have read the manual and do not find a reference to a " normal " or " excessive " numerical number for tranny temp. It only refers to the gauge moving to the danger area if overheating occurs.
After running 70mph on the interstate for an hour or so on my first trip the numerical temp was 194 +/-. The gauge shows mid range or normal.
Just curious what other ecoboost owners are seeing as a normal tranny operating temp. I ask because mine runs 15-18 degrees warmer than my old F150.
Yes, I do realize different engines operate at different "normal" temps. It just seems if the manufacturer gives you a temp gauge they would also tell you what is / is not normal ( a range ). Surely individual engines of the same make /model would have similar operating temps. wouldn't they?
  • riven1950 wrote:
    I'm the OP so no expert, but mine was running lower just driving it locally. When I got on the interstate for an hour or so it stayed pretty much at 194. Maybe it takes a while to get to optimal temp.?
    I don't own an Eco but I have a Scangauge II that I swap between our 3 vehicles and I've noticed that, across the board, the transmissions do in fact take quite some time to get fully warm.
    Based upon replies from other Eco owners mid-190s sounds like normal operation and no cause for concern :C
  • 212 has been the highest I have ever seen ours. That was on a 7%, 8-mile long grade. As soon as we topped out, it came back down quickly.
  • I'm the OP so no expert, but mine was running lower just driving it locally. When I got on the interstate for an hour or so it stayed pretty much at 194. Maybe it takes a while to get to optimal temp.?
  • Wonder why mines a little cooler? I baby it when driving...could that be it?
  • Thanks folks, at least now I know mine is within the new normal range. Thought it was as the gauge is planted right on normal after full warm up.
  • 210 pulling the grapevine with my rig... Just keep moving.. :)
  • The newer transmissions are all regulated to run hotter to improve efficiency. Actually, same with the engines too. 209F is the new normal T-stat full-open temp, where 10 years ago 190F was the norm, and 20 years ago it was 180F.
  • I've only run unloaded so far (break in). I am typically at 175 on back country roads putting along. Have gotten to 190 in city driving.
  • I've never seen over 205F with an 8800lb 5th wheel but that's in the midwest with no long grades. I also have the max tow/HD payload package so if you have the standard towing package without the extra cooling, it may run warmer. Unloaded, it's in the 195F range, like you have seen. I wouldn't worry until 230F but I think you'll have a hard time getting there.
