Triker33 wrote:
The newer 3.5L Ecoboost F150 has 365HP and 420 lb ft torque
Ram 5.7L Hemi 395HP 410 lb ft torque.
Both at the flywheel not to the wheels.
Did both turbos go out or just one? The 3.5l does have 2 you know.
My toad has the Ecoboost 3.5l but it's only rated to pull up to a 1,000 lb trailer. :(
Had a dyno on it after some work including new down pipes, 93 octane tuner, 3 map, 160 thermostat, plugs, Airaid air intake, muffler change ended up at the wheels 355HP & 380 lb ft Torque
The new 2017 Gen 2 Ecoboost for the regular F150 is 375 hp and 470 lb-ft.
Also, are you sure you dyno'd that thing correctly? I pretty much had about the same mods and pulled 365 hp and 460 lb-ft at the wheels(about 420 hp and 530 lb-ft at the crank with a 15% drivetrain loss). So did many others with the same mods on the forum. Who is your tune through?
