BenK
Aug 28, 2019Explorer
in simplified terms...
At sea level, we breathe 1 atmosphere worth of air. Ditto an ICE (internal combustion engine. Both Gasser and diesel are ICE's)
Turbo charge, or super charger (one uses exhaust gases to spin a compressor wheel forcing more air into the ICE, other uses belt driven compressor) forces more air at sea level.
How much is normally discussed in terms of PSI (pounds per square inch that the air will impart on it)
Think of that as forcing in 2, 3, or more atmospheres into the ICE. Tidbit is that now stuffs in the amount of air a larger displacement ICE would inhale, but stuffed into a smaller displacement
When going up in altitude, the air gets thinner. Humans need to have an oxygen mask to help breath. Same amount of air, but more O2
With forced induction (turbo or super charger) will stuff more air and that compensates for the thinner air
Hope that helps you understand
Mickeyfan0805 wrote:noteven wrote:
Turbocharged engine do not starve for air at high altitude so produce their rated power you paid for.
I'm fascinated by this. There is long-common rule of thumb that you need to compensate your tow rating, with gassers, for high altitude towing. Are you suggesting that the EB, though a Gasser, reduces/eliminates this concern?
These are great responses for those of us less knowledgeable on engines. Thanks to everyone!
