FishOnOne
Sep 06, 2019Nomad
JRscooby wrote:ShinerBock wrote:JRscooby wrote:
Where is it written that gas engines must be V whatever? What would happen if they put modern fuel and spark control, and a turbo on a 5 L I 6?
They probably don't do it because of the cost associated with re-engineering a whole new motor/supporting systems and completely re-tooling the factories. It is much easier and more cost effect to re-scale and take away cylinders for various displacement sizes of a certain block configuration versus having two block configurations.
Cost associated with re-engineering a whole new motor/supporting systems and completely re-tooling the factories? IMHO, they did that.
Had a engine that was pretty cheap to run, and real dependable back when using points and carb. Instead of putting Fuel Injection on that when needed to clean the exhaust everything had to go V. Ford put throttle body on the 302 V8, and made big improvement in power and economy. Why not the 300 inch 6? If they had, then would not take much to add the turbo
Ford did upgrade their I6 with fuel injection and it still was a turd to drive.
