danrclem wrote:
APT wrote:
Area under the torque curve is what most drivers notice. The green line shows how much torque is available under about 4500rpm than any other compared engine.
I haven't ever had an engine with a turbo so I'd like to know how they work. First of all that's a very impressive torque curve for the Eco Boost. I wish my 6.2 had one like that. When it's running 2,000 rpms would the amount of torque shown be with the turbo running? Does the turbo start running at a certain rpm or at a certain level of throttle position? If the turbo isn't running at 2,000 rpms would the torque be less?
Just wanting to understand a little more.
The turbine side (wheel with fins like a fan) of the turbo is in the exhaust stream. Anytime your engine is running, your turbo is spinning.
The compressor side (same, like a fan) of the turbo is in the intake tract. This also spins anytime the engine is running.
The turbine wheel and compressor wheel are connected together via a shaft.
At idle the engine is drawing in more air then the turbo is pushing.
At certain throttle and load parameters, the turbo will start to push more air than the engine is pulling in. Thats boost.
The more exhaust your engine makes, the faster the turbo will spin. Up until the wastegate opens. The wastegate is an exhaust "dump" to only allow so much exhaust through the turbo. This therefore is another control of how much boost is being pushed into the engine.
Just a brief explanation of a turbo.
I could literally write for half a day explaining this. So if you want an indepth understanding, its just best to google it or youtube it.
