Perrysburg_Dodg
Jun 09, 2014Explorer
brulaz wrote:Perrysburg Dodgeboy wrote:
Well that could be said for the Ford Eco-Boost engines also. A V-6 gas with twin turbos towing a 7-10,000# TT will be at WOT and full boost also.
Full boost maybe but definitely not WOT.
You really don't get the low-RPM torque thing ... :)
Well explain it then, keeping in mind the Ram will have an 8 speed trans and the Ford is running a 6 speed. You do know that the Ford EB does or did do the same thing right? Even towing no where near it's tow rating. Here is a guy towing a 7-8,000# reporting overheating at high altitude. LINK
So given the fact that the test truck they used was not really set up for towing, 3:55 gears not the 3:93's. Considering "We saddled up the EcoDiesel first and loaded it up to 105 percent of its gross combined vehicle weight (GCVW) rating of 12,800 pounds. The Ram 1500 had no issues accelerating from a stop, getting up to speed, or slowing back down." Read More. I have said it meany times but I'll say it yet again, THIS TRUCK IS NOT INTENDED TO TOW A HEAVY RV!
But given the fact that Ford owners were reporting over heating well below their trucks rated 11,500# tow rating I would say the little under powered Eco-Diesel did better then the Eco-Boost.
Has Ford addressed the over heating issues? Yes they have, but given the Ram was overloaded and not equipped with the correct gears for towing, I would say it did a damn good job.
Also remember they reported it achieved 19.46 MPG fully loaded. The 2014 F-150 Ecoboost is rated at 17/23 mpg. So the Ram beat the EB's city mileage TOWING over loaded and was only 3.5 MPG less then the F-150's highway mileage. Note that the Ford mileage is UNLOADED and would be a stripper model set up for the Government EPA rating tests.
Don
44,072 PostsLatest Activity: Aug 30, 2026
