westend
Sep 25, 2015Explorer
If you're worried about weight on the roof, use some plywood or expanded foam sheet to spread out your weight.
FWIW, I'm getting up there in years too and finally realized that I don't have to do everything myself (as much as I'd like to). I've already put in a lot of time at hard work and I figure a guy can draw a line somewhere. Otherwise, you'll probably read about me in the papers--"Shorewood man breaks back/neck/skull while trying to clean RV".
Good luck with your projects!
