Xpd77
Nov 23, 2014Explorer
Just so you have some numbers to go by I have a 2012 F350 srw crew cab, short bed. It has a GVWR of 11500 lbs. A similar F250 has a GVWR of 10000. My Arctic Fox 811 with a full tank of water and loaded up for a weekend of camping weighs in at 4620 lbs. This puts me over my weight limit by 1200 lbs. If you are going with an F250 you will be over weight by 2700 lbs.
Hope this helps, although not to your original question. I have 20s on mine and will be upgrading to a higher rated tire in the spring.
44,059 PostsLatest Activity: Mar 18, 2026
