Bedlam
Nov 24, 2014Moderator
The F250 suspension with camper package handles the weight of the AF811, but sags too much before the overloads are enabled. Using both the upper and lower Torklift StableLoads solves this problem without having to use air bags. If you plan on more than 7000 lbs rear axle weight, you will need the additional assistance of air bags, upgrade the rear spring pack or consider starting with a DRW.
I was happy with the OEM stabilizer bar, but some people have reported even better handling with the Roadmaster.
44,059 PostsLatest Activity: Mar 18, 2026
