So I took the three wires apart. Two of them are okay and I have all my lights back. The third wire made the fuse blow. The LP detector is on that circuit, but not sure what else is yet. I have isolated that wire for now.
However the lights are not as bright as they should be and they seem to pulse some.
If I disconnect the shore power I have noting. The battery is connected and all the jacks still work.
Could I have a bad distribution block in the front by the battery or there is no 12v power coming through the power panel. Therefore when I am hooked into shore power it is only being fed from the converter.
