Stefonius
Mar 14, 2014Explorer
wmoses wrote:I use mine the same way as wmoses does. Lately I've been wondering if a pair of heavy duty bottle jacks under the frame behind the axles would help to alleviate some of the remaining wobble. Does anyone do this?bigcitypopo wrote:I use mine as designed ... to stabilize the rig (i.e. remove large scale displacement from side too side / end) I set them down onto plastic pads then snug them up so that the trailer is lifted maybe 1".
these things aren't designed to lift your rig ... but how do you get minimal wobble/shake..any idears....
There is still "wobble/shake" but no "tip over tendency". To get rid of any more movement you need a combination of X-chocks and vertical supports between the span of the stabilizers preferably in way of the axles.
Of course this type of question will again attract a lot of responses and hopefully by the end it will become clear. ;)
44,066 PostsLatest Activity: Oct 04, 2013
