tmac00's avatar
tmac00
Electric Awning Question
We have just taken possession of our new Palomino 23 BH and are excited to get out camping. The question I have is about the Electric Awning. The tech at the place we purchased could not stress more the fact the awning is a "Sun Shade" and should not be expected to withstand any wind and or rain. He kept repeating this to the extent that I am afraid to leave it up overnight for fear of a heavy dew "ripping it off of the trailer"! We are long time PUP owners and have used the awning during monsoons, any suggestions? Thanks.
  • though i'm not a fan of electric awnings, any awning stands the chance of being damaged, if no one is around to put it up if bad weather/wind shows up.
    it's always advised to put your awning up if you're leaving the campsite for an extended time, especially if you are camping in an area that has unpredictable wind/weather.
    we don't get much bad wind or weather out here in California, so we've left our awning out overnite.
    but if we lived somewhere else, we would probably put it up.
    even with a manual awning, it only takes a couple of minutes to put it away or up.
    not worth the risk.
  • I agree with all of the above.
    You will learn about your own particular awning from experience. Assuming this is a brand name awning, like a Carefree, there are some things that are fairly certain.
    First - A little wind is not a problem.
    Second - A little rain should not be a problem.
    Third - Unless there is a promise of thunderstorms, leaving the awning out at night is not be a problem.
    Fourth - Gusty winds are a bigger problem than constant winds. So that turbulence that comes just before a storm is not to be ignored.
    Fifth - An electric awning that cannot be lowered on one side is not always a problem in terms of pooling of water. It depends on how much slope there is. I have never actually measured ours, but I would very roughly estimate it is something in the neighborhood of around three feet, give or take maybe six inches. (Trailer is 12 foot high, awning is mounted somewhere around the 11 foot mark, and I can touch the awning at its lowest point/maybe 8 foot above the ground) So 11 minus 8 is right around 3 feet. In contrast, the guy that was camped across from me last winter had an electric awning that had almost no slope. It was an easy 9 foot off the ground at the lowest point, maybe even more. The bottom line, my awning has never collected water in the past five years, and we are snowbirds, so our awning has seen a lot of rain. My neighbor, on the other hand, retracted his awning every time it rained.
  • I have an adjustable arm electric awning. I will pitch it on an angle and leave i out overnight. I will not leave it out if I leave the campground though in case high winds move in. Also, remember it best to be level when retracting it...so if you have it pitched, reset it to even up the arms then wind it in. Also, I've found that if gets a little windy at night, the electric awnings tend to flap in the wind. Hard for me to sleep with that added noise, so I will get up and roll it in if that happens.
  • joelc's avatar
    joelc
    Explorer III
    I liked my manual awning on my old 5er better than the electric, non-adjustable, on my new one. Mine is a Carefree Awning and they do have a kit to make it adjustable. But yes, awning should be left open in the wind. If it is just raining then no problem, but if you see it flapping bring it in. I also always bring it in if there is a T-storm, as there is always a good wind with them.
  • If your awning is the type that doesn't have adjustable arms then yes, he is exactly right. I hate my electric awning. I have no way to adjust one side lower than the other so rain can run off. I left it out during a light rain and water started pooling in the middle. If I had not been there the extra weight probably would have eventually bent the tube or separated the fabric from the TT. I would much rather have a manual awning.
  • If the winds are strong and making it jump and the rain is a monsoon,, bring in the awning. You push the button and it winds up. Better safe than sorry. Yes, that is what insurance is for but having an awning torn off your camper, means your camper has been permanently damaged !
