ajriding
Aug 09, 2019Explorer II
There is a big difference in the Danfoss-style compressors and the less expensive dorm or household fridge compressors that do put out lots of heat and eat up a lot of power.
The RV / portable compressor fridges will not need outside venting. It seems better to put the heat into the cabin than to let hot air circulate over the back of the fridge, which will be hard to seal off. If it is a chest freezer then very impractical to seal off.
If you have an AirC running then you will not need to worry about the state of charge on batteries, and if you are running the fridge off batteries (likely not plugged into AC power), then the cabin air is cooler than outside, and will be vented out the roof vent and never really add heat to the cabin anyway. If it is cold outside then not issues at all.
If you are putting a giant house fridge in your camper, then you probably drive from electrical outlet to electrical outlet, or always on generator, so power consumption is much less of an issue than those boondocking.
It doesnt matter how you vent household fridges.
44,066 PostsLatest Activity: Apr 16, 2026
