Chris_Bryant
Aug 09, 2019Explorer II
neschultz wrote:stevemorris wrote:neschultz wrote:PNW_Steve wrote:
If you close off the outside vents you are going to come up with some sort of ventilation for the condenser.
Why, my residential fridge at home doesn’t vent to the outside?
In my case, the condenser is in the bottom and I figured that air would go in at the bottom and out the top and sides, just like in a house.
I have been thinking about closing the top vent though to prevent moisture and outside temps from leaking in. You think that’s a bad idea?
compressor fridges don't need ventilation they need circulation. all fridges give off heat, a fridge with no ventilation will heat up your trailer, big difference between a 100 sqft trailer vs 1000 sqft house!
I don’t think that heat from the refrigerator is a big concern. Our 10 cubic foot residential model only uses 140 watts when it’s running. And our 40’ 5th wheel is at least 400 sq. ft. with the 4 slides open.
Keep in mind it’s a heat pump- you are getting way more than 140 watts of heat, you’re probably getting 3-5000 btu of heat.
44,066 PostsLatest Activity: Apr 16, 2026
