wgriswold
Nov 16, 2014Explorer
Electric heating via an inverter is a very bad idea. The 12.5 amps at 120V will be at least 125 amps at 12V and more because the inverter is not be 100% efficient. Assuming 80% efficiency, the amp draw will be 156 amps. That would deplete two batteries in about an hour.
A much better idea is to use the propane heater. Even that will require a backup source to charge the batteries every day or two because the fan in the heater uses a lot of electricity.
44,067 PostsLatest Activity: Jun 02, 2026
