John___Angela
Nov 16, 2014Explorer
Are you adding an inverter as I'm not aware of an Arctic Fox 25P having one. Are you confusing it with a converter? If so the heater will not be in anyway connected to the converter. The converters function is to convert 120 volts to 12 volts. The heater will plug into a 120 volt outlet which is no way connected to the 12 volt system.
Hope this helps.
Hope this helps.
44,067 PostsLatest Activity: Jun 02, 2026
