MM49
Nov 17, 2014Explorer
Captain Skippy wrote:
Yeah, some of the post lost me but I appreciate all the comments. I'll use the electric heater along with the propane when it gets below freezing. The Arctic Fox has enclosed tanks and heat vents. I'm buying a heated fresh water hose and an extra heated pipe wrap for the park's water stem. We should be fine. I always have some extra drop cords should I need to run an extra to the electrical supply. Shouldn't be too bad. Cold here is mainly 20s, occasionally in the teens. Thanks.
I think that you should consider a load shedding strategy. My TT can pop a 30 amp breaker without a sweat. I don't have half of the loads you are considering.
MM49
44,067 PostsLatest Activity: Jun 02, 2026
