DownTheAvenue
Nov 17, 2014Explorer
You don't have an inverter, you have a converter.
An inverter changes 12 volt battery power to 120 volt power to outlets.
A converter changes 120 volt coming into the trailer from the shore power to 12 volts to power interior 12 volt lighting and battery charging.
An electric heater will be using only the 120 volts from the shore power.
If you use too much 120 volt appliances, you may trip circuit breakers.
You will have 30 amp shore power service on the Artic Fox 25P.
44,067 PostsLatest Activity: Jun 02, 2026
