Gdetrailer
Nov 17, 2014Explorer III
myredracer wrote:Gdetrailer wrote:
Nvr2Loud writes “You are not correct. A 50 amp 240 volt shore power breaker is capable of producing 50 amp maximum (not 50 amp per line)
If it was DC current, you would be correct, however it is AC current we are discussing.
An entire house with dual 100 amp main breakers is capable of running 10 amps total, not 200 amp.”
:R :h :E ??
Sorry but you are wrong.
Yup, your correction is correct, but your essay only gets a 99/100 grade marking. :B Just to clarify, that panel wiring diagram is for a main panel in a house and not the sub-panel in a house or the one in an RV. The neutral can only be grounded in the main panel by Code and is a serious safety concern.
I didn't want to confuse the already confused Nvr2loud with the idea of SUBPANELS and the rules on how they must be wired.. :S
44,067 PostsLatest Activity: Jun 02, 2026
