rockhillmanor
Nov 07, 2015Explorer II
DutchmenSport wrote:
"The KEY in an RV is too make sure you keep the cold air OUT."
The problem with sealing up the inside of your RV without some kind of continuous air flow is the fact condensation will form if it's really chilly outside. People have posted on these forums the condensation is so bad in their campers, they've even had drops of water falling from their vents over their bed.....
I have never experienced condensation on anything inside my MH. Something is way wrong with that picture unless the 'RV itself is so poorly insulated'. That would be the only way it would condensate that much.
Maybe if you have 6 people in your all RV taking showers, washing dishes, cooking, poorly insulated RV, etc etc while the heat is on, yes you most likely will get some condensation! But I have never heard of a couple in an RV getting condensation while using the heat.
