SoundGuy
Feb 25, 2017Explorer
wade68025 wrote:
Looking for a new electric tongue jack for my Jayco travel trailer. Any thoughts on brand, model or even where to buy at a good price.
Last year I replaced the LCI tongue jack that came with our Coachmen with an UltraFab 3502. I chose the UF because I had owned one previously, preferred the all metal construction, and the fact that by loosening the four head bolts I could rotate the head 180 degrees and thereby avoid the truck tailgate. The internal design of the UF has changed so rotating the head is no longer possible without completely disassembling it BUT it now does come with extra holes in the base plate so it can be mounted so the head is sitting 90 degrees to either side. Since I'm normally standing on the street side of the trailer when operating the tongue jack that's how I set it up.
Many tongue jacks will have a plastic head cover, either white or black, that in time will discolour and deteriorate from exposure to the elements, particularly the sun. Even though mine is all metal I also keep it permanently covered with a purpose designed UltraFab tongue jack bag.
When selecting any tongue jack make sure you know the size of hole you have in the trailer A-frame, either 2" or 2.25". Most are the latter, including mine, but since the UF 2502 has a 2" lower shaft I built a support bracket using a piece of hardwood.
One caution - there are plenty of much less expensive look-a-like tongue jacks for sale online of eBay, etc, that you'd swear are UltraFab but in fact are not. JMO, but you usually get what you pay for and I expect this will be the last tongue jack I'll ever own. ;)
44,025 PostsLatest Activity: Feb 26, 2025
