chilly81's avatar
chilly81
Electric trailer brakes uneven drag around rotation
I'm replacing the brakes with brand new dexter assemblies, hubs, bearings right now.
I put the new ones on and I'm getting uneven drag on a couple of them. Like I can spin it and it will rotat through 270degrees of rotation then the drag will stop it and I have to turn it through the last 90 degrees by hand. It's not like it's hard to turn, but it's definitely dragging the brakes more significantly during that portion.
I can't envision a scenario where this has anything to do with my spindles or the backing plate. It really has to be the runout of the drums or possible the bearing races - as those are the only moving/rotation components.
Anyway - is this normal or acceptable to some degree? Kind of bummed these are brand new parts and I'm a bit worried.
btw, these are self adjusting and I haven't yet applied or adjusted them - but they are obviously close and dragging some at some point during rotation.
Thanks.
  • Normal because the drums simply aren't round. For some reason they just can't seem to machine them round. Even new ones are that way.
    So while it's not desirable, you would have to get them turned (if there's enough metal on them) to keep them from being out of round.
    Mine have got around 50K on them and they have always done it.
