Gdetrailer
Oct 19, 2020Explorer III
Lwiddis wrote:
And your payload is 1173 pounds. Very low. Hitch weight and the hitch itself on 5000 pound loaded and wet trailer will be 700 pounds or so, leaving you with 473 pounds for people, stuff. Not safe.
OP is looking at a trailer that is 3,500 lbs GVWR, not 5,000 lbs GVWR.
Big difference between the two.
From the first post and I am hot linking the page that was in that first post..
https://www.rvusa.com/rv-guide/2013-jayco-jay-feather-ultra-lite-travel-trailer-floorplan-x17z-tr13211
For those that don't wish to look at the link, I am posting the specs below..
"Specs for 2013 Jayco - Jay Feather Ultra Lite
Floorplan: X17Z
Weight
Dry Weight
2,900 lbs.
Payload Capacity
600 lbs.
GVWR
3,500 lbs.
Hitch Weight
405 lbs."
If this IS the choice the OP is looking at, then there should be no issue with the available payload they have and is why I mentioned OP should be OK with it.
I commend the OP for looking at a lighter trailer than most folks would have, gives the OP some breathing room in capacity without the need to scale everything before putting it in the trailer.
