mr_andyj
Oct 19, 2020Explorer
There are some on this forum that would not tow a small flat cargo lawnmower trailer with a semi-truck because it could be too dangerous. You are safe to go by the auto manufacturers recommendations, but it is a lot easier to tow that lawnmower trailer with a semi-truck if you are looking for the maximum amount of ease, as some on here are.
Maybe you can do the wiring yourself maybe you cannot. When I started I was asking the same questions, but did it all myself and it was easy, just you need to know what wires to tap into and where the "brake" wire is on your vehicle. It is usually a light blue and only a couple feet long originating from under the dash. It goes towards the back, but goes nowhere, so u have to find it then splice into it.
Controllers are $30 and up. If you will not tow much you can get by with a cheap "timed" one. If you will tow a lot and like nice things then get a $200 "sensor" type where the module senses the amount of braking you are doing and brakes the trailer accordingly. It is so much nicer. i have had both types and will never go back to a cheap one.
The other 2 of the 3 extra wires from the flat-4 to the 7-pin are reverse lights and a 12 volt charge to keep voltage on the trailer camper battery while you drive. You can get away without reverse or voltage, but legally you need to hook up the brakes, and especially the weights of TV and trailer you are stating... You will also need a working "breakaway" emergency brake control and to keep a charged 12 volt battery connected to it from the trailer.
