Dog_Folks's avatar
Dog_Folks
Explorer II
Sep 07, 2014
Electrical Experts Please
A trailer we are considering is pre-wired for two A/C units, but it only has one. It is listed as 50 amp.
Would this mean that there is more amperage available for general use?
For example, in our 30 amp trailer we cannot run the A/C and the microwave at the same time if the electric water heater is on.
Would a 50 amp allow that for example?
Is 50 amp service really an advantage over 30 amp?
  • nomad297 wrote:
    Dog Folks wrote:
    I guess 50 amp vs 30 amp will become a higher priority when shopping.
    It will also become a higher price at some campgrounds. I have seen campgrounds that charge from $5.00 to $10.00 additional per day if you need a 50 amp hookup. I imagine more and more campgrounds are going to start doing this. Most of these same campgrounds also have written in their rules that no electric heaters are allowed.
    Bruce
    Valid point. I have seen some campgrounds already charging up to $5.00 a day extra for 50 amp. Thanks for the reminder.
    Bruce
  • Outstanding! Question posted at 10:32.
    Two expert responses within 7 short minutes.
    Thank you both, I guess 50 amp vs 30 amp will become a higher priority when shopping.
  • Hi,
    If the 50 amp is sensibly wired you should be able to run everything at once. Each "leg" can have up to 6000 watts, so there is more than three times as much power available, provided that there is good solid power at the campground, than in a 30 amp service.
    It is important to have a good top of the line surge suppressor if going to a 50 amp service.
  • If the trailer is a 50a system, and if 50a is available at the campsite you are in, then yes, you will have more amps to run more appliances at the same time.
