Farm_Camp
Jan 27, 2014Explorer
If you have a 30 amp rig get the 30 amp protector. Yes. You can safely use a 50 amp unit but it's not going to be any better (or worse) than a 30amp.
I expect the 50a will cost more. If it were me - knowing what I know - I'd spend those extra dollars getting a little higher end 30a unit.
Now I am not the absolute expert in electrical protection devices. But I do not believe spending extra money on a 50a unit for a 30a camper is going to do you any good - although it would likely do no harm either.
The Amp rating refers to the current that can safely flow through the unit. It will not cause (or prevent - unless the protection circuit kicks in) current flow (amperage).
(edited)
Your breakers are there to stop too much current (from a short or overload) from overheating your wiring maybe causing serious damage or fire. The Protector saves you from spikes or dips in voltage and other line issues that can damage motors/electronics and also maybe cause other damage - but the two serve different purposes in general terms.
Hey! Didn't notice at first. Welcome to the club! ;)
(edited)
